Hotpoint 1604321 module
  • #30134
    I have two Hotpoint WMA modules, one I am certain is a 1604321, the other has lost its box 😳 .
    The label on the first one shows AKO 547 004 HW01, GDA 1617205604, Mask Index 019, the other has AKO 547 005 HW01, GDA 171725605, Mask Index 021.
    I am almost certain that this is also a 1604321, can anyone confirm this?
    The first one is completely goosed due to a COMET engineer making a complete horlicks of the motor plug, the full motor to module harness is around a fiver for gods sake, he decided to replace the plug with separate AMP tags instead, the harness was left flopping around, the wiring broke and shorted against the motor. 😥
    HotDog
    Re: Hotpoint 1604321 module
    Hi jim can confirm 1604321 is correct for your first code number not sure of the next one will see if i can find info on this 🙂 🙂
    #226029
    Hi Cliff, I am 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure, just wanted confirmation before I send it off to be repaired, the other one is beyond repair. 😥
