Hotpoint 31358
  • #26861
    clivejameson
    Can anyone supply us with the parts diagram and parts list for this machine please?
    #211665
    hotpnt
    Re: Hotpoint 31358
    what is it?
    #211666
    clivejameson
    Re: Hotpoint 31358
    Forgot to say it’s a condenser dryer!
    #211667
    hotpnt
    Re: Hotpoint 31358
    I Think you mean a CTD85, 31358 would be the comercial code
    #211668
    don
    Re: Hotpoint 31358
    Hi Clive
    31358 is the commercial code for a CTD85A.
    Don
    #211669
    clivejameson
    Re: Hotpoint 31358
    Thanks Don
    Connect shows the drum support wheels as no longer available but shows a felt bearing kit instead….is this a modification or is this the end of the machine?
    #211670
    clivejameson
    Re: Hotpoint 31358
    ….and thanks hotpnt too…
    also forgot to ask if anyone has the part no. for the rear bearing retaining collar, the castlated affair that the locking pin slots through.
    #211671
    hotpnt
    Re: Hotpoint 31358
    Hi, the front wheels were deleted because they made such a racket, the kit is 1703272 contains belt & the front pads for front duct, as for the rear part, not sure which bit you need but if the shaft has any wear then the kit 1701662 has all you’ll need, new shaft & screws, plus all the fixing bits/pin/collar/bearing
    #211672
    clivejameson
    Re: Hotpoint 31358
    The shaft and bearing have little wear to them, but the rivetted bearing holder is loose on the back panel and it’s flanges that secure the bearing are bent allowing the bearing to drop a little causing the drum to drop slightly.
    It strikes me that these small pop rivets aren’t man enough for the job…is there room to nut and bolt the bracket to the back panel without the bolt heads fouling the drum?
    #211673
    hotpnt
    Re: Hotpoint 31358
    it would probably be very close to the back of the screws securing the shaft plate to the drum, the kit 1701662 comes with the bearing holder plus 2 new rivets, i dont think the holder is available on its own,
    #211674
    clivejameson
    Re: Hotpoint 31358
    Connect have a lovely pic of 1701662 but it doesn’t show the bearing holder and rivets…have you ordered one of these before ?(don’t want to order it then have to order a complete back panel afterwards)
    If it does come with the bearing holder then that’ll be job done 😉
