Hotpoint 6.5kg BHWD129
  • #99736
    Graham Smith
    Second time on this site in a fortnight! First it was my dishwasher with a faulty diverter valve, now I find myself asking questions about our washing machine.
    Put the machine on this morning, and on spin, it started to make a terrible noise.
    Does this sound like the drum bearings?
    Is there anything else I should be looking at?
    http://www.pinecrest.co.uk/washing_machine/IMG_5283.MOV
    http://www.pinecrest.co.uk/washing_machine/IMG_5284.MOV
    http://www.pinecrest.co.uk/washing_machine/IMG_5285.MOV
    http://www.pinecrest.co.uk/washing_machine/IMG_5286.MOV
    #477681
    that sounds like a drum problem
    spin the drum by hand and see if anything is catching. had one the other day and it was a screw causing the problem
    andyjawa
    Initially it sounds like a fractured drum spider to me and if so a complete new tank assembly but maybe under 10 year freebee parts warranty and if so use it. BUT common and not so common cock-ups with these things in no particular order of hoplessness are: front weights break/crack or simply come loose – quite common. Top weight comes loose- possible but not that common, drum pulley spoke fracture ( not too common that one ), chassis splits under damper legs ( though that is a ticking noise but very common ), plastic tank splits around bearing tube usually visible near pulley ( had that one a few times ). Typical of any C21st product and that is it is compromised and prematurely fails. So some pointers to check.
    To check for a fractured spider arm: each of the 3 drum paddles line up with the 3 spider arms which of course you cannot see. Using your thumbs hold as much as possible through the back of the door seal the plastic tank still ( as the whole plot is on springs ) and with the other fingers push down on the drum at each 3 points or fingers in what order suits you. Any movement in the drum relative to the tank indicates a duffy spider. If the fracture is near the hub, that is the thickest bit, this suggesttion might not work. You`ll just have to pull the bugger out and go over these listed pointers.
    #477683
    andyjawa
    ps check the dryers fan motor is not loose
    #477684
    Graham Smith
    Thanks for all your help guys. Once I removed the drum, it was clear the bearings had suffered a catastrophic failure.
    Will report back once I manage to get a new tub.
    #477685
    andyjawa
    All the best with your repair.
