Re: Hotpoint 7822 not emptying
The pump can be accessed by removing the lower front plinth. Be sure to remove the mains plug and if possible pull the machine forward then lean back against a wall or kitchen units.
There is no access to the pump from inside the tub on this machine.
The pump is situated bottom right and can be removed for inspection or replacement without to much trouble.
There are two different pumps, one under £30 the other nearer £50. It may be blocked but at that age it could easily have seized. Serial number needed to identify correct pump.
If the older ( dearer ) pump is not available it is possible to fit the later pump but you would also have to change the outlet hose as well.
The later pump is in our Shop@
