Hotpoint 7kg Ultima Digit WT761 H20 error message
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint 7kg Ultima Digit WT761 H20 error message
  • #81843
    ruwise
    Hi All,
    Really hoping somebody can help me as I am due to go on holiday soon and my washing machine has developed the above fault.
    We had to move the machine only a few feet the other night so did disconnect it and re-connect it and it is since then that it has developed this fault. We have checked that the hose is connected to the cold water supply tap. It is turned on and the hose is not kinked. We don’t know how to check the water pressure but when it was not connected the water seemed to be coming through fine.
    It does feel like it is filling up to a point but it is not going any further.
    Has anybody got any ideas??
    #417869
    Muv
    Re: Hotpoint 7kg Ultima Digit WT761 H20 error message
    Unplug your machine from the power completely, remove the lid, and look just under the soap drawer, you will find a small tube that leads up to a pressure switch, this usually comes adrift when the machine has been moved, if it is still connected, youncan try blowing down the tube, then re connecting again… This should solve your problem…
    Muv
    Sotty by blowing down the tube, i mean disconnect it from the pressure switch, and then blowing down the tube whilst is is disconnected…then re connect
    #417871
    ruwise
    Thanks will try that!
