Re: Hotpoint 9404W
robbra wrote:Hope you can understand this
100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Rob. 🙂
The 2 major issues that effect the spinner from not spinning are: –
1, The top bearing (phospur bronze collar) crudded up and complete removal of spin can & shaft required to sort that. Clean the shaft with emery cloth, smear loads of grease on the shaft and into the bearing collar beneath the tub bellows seal. Refit the spin can and spin it by hand. It should spin nice and freely then at that point prior to re-assembly.
2, The brake release bowden cable should release the brake band once the lid is shut. The spin lid lever and it’s attendant mechanism can be the source of the problem. With the back panel off and lid shut you should see the lid lever lock in a vertical position and force the bowden cable down. Often the lid lever wears or the cable jams through lack of lubrication. So a good dose of 3 in 1 required all round!
The brake band adjustment can also be a minor issue, the adjustment is fine to say the least.
HTH? 😀
