Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint 9404W
- This topic has 17 replies, 10 voices, and was last updated 16 years, 2 months ago by
robbra.
February 3, 2010 at 6:13 pm #52201
robbra
ParticipantHi,
never had much to do with H/P twin tubs so,
spinner motor belt spins ok and the aluminium pulley spins but the large cast things ??? and the tub stay still. Did not delve further as I don’t know what it could need or if it’s obsolete or whether it can even be taken apart. An old couple in their late 70s so if I can help it would be nice. Either a fix or a new spinner.
RobFebruary 3, 2010 at 7:27 pm #310915helo_75
Participantcould just be clutch shoes
if u undo the bolt and pull the bottom pulley off, ull see them
it was common way back then
are they still available?
im sure old man jim will know
February 3, 2010 at 9:04 pm #310916leavemetogetonwithit
ParticipantRe: Hotpoint 9404W
In stock at Connect. Won’t say price for fear of starting price discussion.
You probably don’t need them anyway, just blow out the dust (without breathing it) and work the old ones on their pins so they move freely. They have a tendency to get stiff to move and refuse to be thrown outwards by the centrifugal force.
Mike.February 3, 2010 at 9:07 pm #310917helo_75
Participantand rough the edges up with a bit of emery paper, that helps
February 3, 2010 at 9:15 pm #310918robbra
Thanks lads.
A mine of information this place.
RobFebruary 3, 2010 at 10:26 pm #310919aqualectric
The spin turret has 2 bearings in it – a oilite phosphur bronze sleeve at the top and a ball bearing at the bottom. The carbon thrust spin seal used to leak and the water would seep into the top bearing rusting the shaft and causing it to seize.
The most common complaint was the motor drove the aluminium pulley but not the clutch drum. The clutch shoes would not grip and the spin can didn’t move. Traces of leaks in the top of the clutch drum are a dead giveaway. Parts required; new seal, spin turret and shaft kit………all obsolete I’m afraid.
The only thing you can do is to remove the bottom spin weight, drop the pulley off with the shoes and remove the drive pin and remove the clutch drum. The spin can will lift out of the top of the spindrier after removing the plastic trim around the can under the spin lid. Clean the shaft with emery paper and grease it liberally. Push some grease into the top bearing, clean the can seals mating surfaces and reassemble. It’ll run for a while; but no guarantees how long it will last. (although I did one over 2 years ago in Poole and it’s still OK).
Rob – if you need a 9404 twin tub for spares I know of one locally…….:wink:Hope that helps,
Steve.
February 4, 2010 at 7:39 am #310920robbra
Thanks Steve,
will look at it and decide then. It isn’t siezed and will turn freely so I might be lucky.
RobFebruary 4, 2010 at 8:24 am #310921wilf
no it wont FEEL siezed but will most proberbly be cured with a clean and grease. takes me back a bit used to do hundreds.
wilf
February 4, 2010 at 8:51 pm #310922HotDog
clean and grease shaft should do the trick but might need bottom bearing eay to fit
February 4, 2010 at 9:12 pm #310923leavemetogetonwithit
Rob, in case you haven’t done this job yet, (hurry up! we want to know what happens), you could have a look at the clutch shoes on Connect 5031680994926 which will show you what shape they are when new. That way you’ll know if the amount of wear is significant.
Mike.February 4, 2010 at 9:19 pm #310924neilsukwg
Use a junior hacksaw blade as a scraping tool to clean off and roughen up the shiny surface of clutch shoes.
Also roughen up the inside of the clutch pulley housing where the clutch shoes are thrown against. Make sure of course no grease or other contamination gets on any of the clutch parts.
February 5, 2010 at 7:45 am #310925robbra
Ok,
Booked for next week. Loads of tips so I can’t fail can I.
Will Keep you posted
RobFebruary 5, 2010 at 8:37 am #310926pup
neilsukwg wrote:Use a junior hacksaw blade as a scraping tool to clean off and roughen up the shiny surface of clutch shoes.
good old days , 😆February 15, 2010 at 4:13 pm #310927robbra
Right….
Went back and took off the bottom cast weight and then the ally pulley with the shoes and the clutch drum. No sign of a leak at all, just shiny shoes so roughed them up and cleaned the inside of the drum too. Put it back as it was and just the same, pulley spins but drum doesn’t.
Three questions,
1, is there anything other than the shoes as I don’t see how they can grip enough to turn the drum or
2, what way should it spin? This goes anti clockwise as you look at the bottom so the shoes are trailing onto the drum and not pushed onto it to grip. Unless someone has looked at it before and they haven’t told me.
Has anyone a diagram of how this goes together.
3.I think the shoes are on the wrong way but not sure, can they be reversed?
Rob
Hope you can understand thisFebruary 15, 2010 at 4:30 pm #310928pup
have u pulled out drum ,have a look make nothing is wrap around it .greas the shaft ,see how u get on
