Hotpoint 9414 twin tub
  • #62662
    robbra
    after 29 years I have to fit a tripod kit and gearbox tube for the first time 🙁
    I have the parts but any tips on how to go about it are welcome.
    The gearbox shaft has some play in it so does the tripod kit hold it and should I debor under the tub to seal it?
    Rob
    #350869
    Re: Hotpoint 9414 twin tub
    robbra wrote:The gearbox shaft has some play in it so does the tripod kit hold it and should I debor under the tub to seal it?
    You would do well to replace the tub support shaft (C00147088) whilst you at it otherwise the tripod carbon seal will quickly fail.
    You’ll most likely need a 3 claw extractor to remove the old tripod. Putting the metal sprung band over the carbon seal and onto the shaft is best done using a short length of fine string or wire. As for debor, well likely as not the rubber tub gasket won’t need it in order to reseal but if you’ve got some handy?
    HTH? 😀
    #350870
    robbra
    Thanks Martin,
    I had to saw the tripod off and that’s when I saw the support shaft(gearbox tube) was split so I have both parts. Is it easy to get the gearbox out? 😳
    Rob
    #350871
    PM me your e-mail address Rob and I will send you a little something. 😉
    Your web site link appears to be borked.
    robbra
    Thanks Jim,
    Tried to send a PM but no send button so here we go.
    xxxxxxxxxxxxxxx
    Website just renewed but stuck for now.
    Rob
    #350873
    😕 Its working for me, you can either use the small PM button or click on a persons name just under their avatar and send a PM from there.
    E-mail sent, I will remove your e-mail address from your post to prevent harvesting bots from getting hold of it. 😉
    robbra
    Thanks Jim
    #350875
    loopey
    no need to remove gearbox .. cabinet off , tripod off , Big plastic nut off at bottom of tub .disconect all leads from tub
    and sump hose , now its been a while since ive done one ….
    now you should be able to pull the top up and to one side so you can remove the tub at an angle ,3 bolts hold the surport
    shaft , and off you go replace the new surport shaft and rebuild . dont for get the tub seal lol , no glue or debore needed ..
    wow that brought some memories back , now iff ive forgot some thing please comment ..
    phil hth
    #350876
    I never even took the cabinet off, just releases the sides, take the spin drum out and pull the bellows seal off the spin spigot, then lift the top surround and spin container and lay it back, then you have complete access to the gearbox.
