hotpoint 9546A
  • #36270
    SWERV
    I ordered a new outer tub ( part no’ 168188 ) but the original tub front does not fit the new outer tub. Does anyone know if there is a different tub front to fit the new tub, or have I got the wrong tub??
    Regards
    Merv
    #250279
    hotpnt
    Re: hotpoint 9546A
    nope, it should fit, but may have distorted out of shape over the years
    #250280
    Re: hotpoint 9546A
    You do sometimes get this problem. I used to find that the best way to overcome this was to build up the drum assembly and fit the drum front before installing the drum back into the cabinet and before fitting the lower balance weight. It just allows you to push and bend the new drum a little.
    evo1
    Re: hotpoint 9546A
    OTHERWISE JUST LEAVE THE BOTTOM WEIGHT LOOSE, FIT THE FRONT PLATE, THEN TIGHTEN THE WEIGHT UP FULLY AFTERWARDS…….
    #250282
    SWERV
    Re: hotpoint 9546A
    Thanks for the advice, it just seems that the old tub is slightly narrower by a few mm.
    Merv
    #250283
    Re: hotpoint 9546A
    I’ve even had the odd WMA drum halves that don’t line up correctly without a bit of persuasion.
    Re: hotpoint 9546A
    Then there’s those Indesit WG tub halves that don’t line up at all……
    hotpnt
    Re: hotpoint 9546A
    yeah the indesits need both back & front half together, bit like the zanussis, but the origional 9546 will just need a bit of persuasion, it may look a few mm out, but it will fit
    #250286
    Re: hotpoint 9546A
    Oh, you can always get an old 95 frontplate on. Washing up liquid and a few sharp thumps always does it for me. Now the old Creda 17 series front plate really was a bugger…. If you got it on, it left a 3/4″ gap at the drum front. Useless.
