Hotpoint 95490 drum direction
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint 95490 drum direction
  • #88882
    robmarshall
    Another elderly machine with a problem that I hope the more senior engineer will be able to shed some light upon.
    During washing, the drum turns anti clockwise only. During distribution and spin, it turns clockwise. No clockwise action with the drum full of water though. Any ideas?
    Many thanks
    R
    #439657
    Re: Hotpoint 95490 drum direction
    probably the timer
    older machine use a reversing contact driven by the motor on the back of the timer.
    when it gets to spin these contacts are not used so machine will turn clockwise
    timer may be still available
    https://emwelec.co.uk/index.php?l=product_list&c=3
    #439658
    robmarshall
    Thanks Dave. In your experience, is there a likelihood it could be the module?
    #439659
    its a simple module with a multiconnector and 2 main terminals and does not reverse the motor its done by the rear timer contacts
    Agreed, timer only thing that controls direction, EMW may still have refurbished timers for these, I fitted one about 18 months ago.
    #439661
    robmarshall
    Thanks guys – just wanted to double-check that there may not be another cause (other than wiring).
    One more request – does anyone have the part number for a new timer? The prices do not look too bad, so it is worth repairing the machine, I think, rather than dumping it.
    R
    #439662
    Listed as obsolete on Partfinder, I will see if I can dig out an old paper manual.
    #439663
    follow the link i posted to the EMW site. its a heck of a lot cheaper and he guarantees them
    Two different timers used.
    168887 will have the number 904-2199-05 on the timer itself ( most common one)
    168481 has 904-2199-04 on the timer body.
    #439665
    robmarshall
    Thanks guys. My timer has 904/2199/03 printed on it!! Would the /05 one do? What’s the difference I wonder?
    Thanks again for all your input 🙂
    R
    #439666
    Not without the wiring modification kit which you are unlikely to find now.
    See if EMW can supply you a timer with the same identification number as yours.
    #439667
    The heater switches changed for one thing.
    #439668
    roly16
    I’ve got two old 904-2199-03 timers if you need one.
    Geoff
    #439669
    robmarshall
    Good morning Gents,
    Thanks so much for looking into this problem in such depth. I took the timer out of the machine last night.
    Geoff, yes please to a timer; please would you send me a PM confirming how much you would like for it, whether or not you can post it out and if it’s new, or S/H.
    A big thanks again ukwhitegoods.
    R
