Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint 9559W Washing machine
- This topic has 11 replies, 3 voices, and was last updated 19 years, 10 months ago by
bigkid.
June 12, 2006 at 10:06 pm #18450
bigkid
ParticipantHotpoint 9559W.
Anyone come across or know of the above machine?Ta … Tony
June 12, 2006 at 11:18 pm #179074burns
ParticipantRe: Hotpoint 9559W Washing machine
Microprofile if memory serves me right.
June 12, 2006 at 11:24 pm #179075bigkid
Cant seem to find a reference to it, models jump from 9556 then start again at 9560.
http://tinyurl.com/r7fmnTony
June 13, 2006 at 12:03 am #179076burns
Tony,
Its listed on partfinder. Whats the problem and what do you require.June 13, 2006 at 11:07 am #179077bigkid
No problem, just couldn’t place the model. was reading the following in an appliance repair forum……… Thought there was one out there I didnt know about.
Ceramic ring ??????????????
regards Tony
> > > The seal isn’t around the shaft, it is the ceramic ring that
> > mates to the
> > > ring on the drum spider, and yes it is a difficult job getting
> > them out, why
> > > can’t you knock it out, has it collapsed?
> > Yes the whole bearing had collapsed and only the outer part was
left
> > in the housing. Couldn’t really get at it properly with chisel
and
> > it was in there very tight. Managed to eventually grind a slot in
> > it and having weakened it was able to knock it out. Housing looks
> > OK tho’ after all that.
> > BUT – Oh Err – ceramic ring? Think that’s destroyed – nothing
there
> > at all. I suppose that the circlip holds the ring on the shaft?
> > So to fit a new ceramic ring I’ll have to remove the circlip?
> > Crumbs this is turning into a tour de force.
> The ceramic ring should be on the drum spider, it is about three
inches in
> diameter and will mat up to the bearing seal when you push it in.
I’ve seen
> several that have snapped, but none that have disappeared. That
doen’t mean
> it hasn’t just that it would be unusual. Ideally you should
replace the drum
> spider with the bearings as a set, it might cost a bit more but
while you
> have the machine apart it is a good idea to invest the time spent
stripping
> it down to do the job right.June 13, 2006 at 11:16 am #179078burns
Looking at the above it looks like someone has made a very big job out of something quite simple.
Ceramic Seal ????
bronze bush comes as part of the drum support. Not excatly costly.June 13, 2006 at 11:23 am #179079bigkid
Methinks confusion over the Hoover ceramic ring and carbon faced seal but like I said, couldnt find the model and thought well, you know what bodges there are out there…… 😯
Tony
June 13, 2006 at 12:57 pm #179080Martin
bigkid wrote:couldnt find the model and thought well, you know what bodges there are out there
The model number, together with exploded drawings and part numbers is on the Hotpoint site Tony, I guess you didn’t look in the right area eh?
(Just type 9559W in the model number search box after opening the link below)
http://www.hotpointservice.co.uk/Service/fr_shop.html
Burns mentioned Partfinder to you, so I guess you don’t have that either?
June 13, 2006 at 1:12 pm #179081bigkid
Nope, never found the need but that aside I know Hotpoint, used to work for them when it was BDA so pride myself in knowing a bit about them but one with a ceramic seal had me thinking.
Incidentally it was the forum moderator who posted about ceramic seals so putting 2 and 2 together thought he knew what he was talking about.Tony
June 13, 2006 at 2:03 pm #179082Martin
bigkid wrote:Incidentally it was the forum moderator who posted about ceramic seals
What site is that you refer to I wonder?
June 13, 2006 at 2:34 pm #179083burns
Bodgers and Codgers, I think 😯
June 13, 2006 at 4:33 pm #179084bigkid
Yahoo appliance-repair
