Hotpoint 9604 Top Loader
  • This topic has 6 replies, 3 voices, and was last updated 16 years ago by Kez.
  • #53196
    Kez
    I am trying to find a relay( for the gear box) for this machine, Connect are saying no longer available, just wondered if anyone might know where I might find one? Cheers Kez
    #314812
    Re: Hotpoint 9604 Top Loader
    Relay for the gearbox. :con:
    You don’t mean the brake solenoid by any chance ?
    List price over £85.00. I wouldn’t be surprised if someone hasn’t got one of these lying around. Might even have one myself, thats assuming you do mean the brake solenoid. No relay of any kind used on these machines since they changed the motor relay to a capacitor nearly 20 years ago.
    #314813
    Kez
    Sorry yes youre right I do mean that part. Will give cust price and take from there. Thanks
    #314814
    Kez
    This ones clunking out on spin so am presuming its that part needed? Cust wants to go ahead so if anyone has one that would be great. Cheers Kez
    #314815
    TBH these solenoids were very reliable, only really changed them due to severe pump leaks soaking them and then burning out. When they put a metal water shield on them the usage dropped to next to nothing.
    When you say ‘clunking out’ on spin what do you actually mean, is the brake lever clunking each revolution or can you actually see the solenoid firing on and off?
    There was a fault elsewhere that used to cause the brake solenoid to fire on and off like a machine gun, its so long ago I can’t remember exactly, I think it was due to the pressure switch contacts arcing. Also due to the water level switches burning out.
    Could also be lid switch needs adjusting.
    If it clunks once each revolution then the brake lever itself is the area that needs attention.
    #314816
    Moved this topic to trade tech in case any other old gits have anything to add. 😉
    Young Jim. 🙂
    #314817
    pup
    iadom wrote:Moved this topic to trade tech in case any other old gits have anything to add. 😉
    Young Jim. 🙂
    what do mean by old gits jim 😆
