Hotpoint 9605 top loader
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint 9605 top loader
  • #20423
    aqualectric
    Hotpoint 9605W top loader. Serial no. 55216532.
    Need part numbers for:-
    Spider and seal (under the gyrator).
    Support turret.
    Drain pump.
    I seem to remember the turret replacement and spider/seal job on these machines being a nightmare job – haven’t (fortunately) had to do one for 10 years ++. Any removal and replacement advice appreciated. 😀
    Thanks,
    Steve.
    #187025
    Re: Hotpoint 9605 top loader
    Pump – 151123
    Support tube was 151213 – obsolete.
    Can’t even find the numbers for the seal kit – definitely obsolete.
    Sorry,
    aqualectric
    Same problems as I encountered – thanks anyway Chris.
    #187027
    Seal kit is/was 151100 still have one in garage, 151123 pump is actually reboxed pattern pump. 😥
    Changing support tube is not that difficult, easily under the hour.
    A real pity they have been obsolete for two or three years now. I have loads of these machines still hanging on, surprised that nobody came up with a pattern alternative, long term.
    #187028
    DAR01
    Tripod (Spigot KIT)
    HPT34 from Qualtex (Includes all you need at top of agitator)
    Bellows Seal bottom of drum is 151241
    You will probably have to apply some heat to the tripod to get it off, plus wd40 and a lump hammer, unless youv’e a puller.
    Mike 🙂 🙂 🙂
    #187029
    Not much use round these parts, the top of the support tube rots away very badly in our soft water, same as drum supports. I would guess I use to around 40 a year for well over 25 years, no wonder I found support tubes easy. 😉
    #187030
    aqualectric
    Condemned to the scrap heap, I’m afraid, as later that day, her son breezes in and says “You don’t want one of those, you want one of these’ and lo and behold she is now the proud owner (loose term) of a new Indesit. When she told me, I declined to mention how deep ‘In de s*it’ she actually was. :rolls:
    Hope she has a spare room for the engineer to live-in……… 😆
    Thanks for the advice and effort anyway,
    Steve.
