hotpoint 9605 top loader pully problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint 9605 top loader pully problem
  • #11768
    i have a hotpoint 9605w top loader the bottom alloy pulley on the agitator drive shaft is badley worn and vibrating badley can i get a replacment
    #146589
    Re: hotpoint 9605 top loader pully problem
    Gearbox pulley is part number 151328. Email to spares@ukwhitegoods.co.uk for prices, availability and ordering.
    In 20 years dealing with these, I have never known a problem with that pulley. Are you sure it is not the pulley on the end of the motor? If so, although it is available, you will probably find that the motor shaft is worn and the only fix is a new motor which comes complete with the pulley.
    #146591
    In 37 years of dealing with these I have seen several gearbox pulley failures 😉 Although motor clutch pulley is far more common. Sometimes the pulley is loose on the shaft but more often the shaft itself is loose inside the oil seal and the pulley shaft has a lot of sideways movement., if so then the repair would be a new gearbox which is obsolete.
    #146592
    In 70 years of dealing with these, I found that they weren’t about for the first 35……… 😀
    I have had 2 or 3 where the nut has come loose and the pulley starts slopping about. These all very quickly changed the key way from a “double D” into a “Figure of 8”. Steel in alloy, no woodruff key, obvious really. No amount of tighteneing will remove the slack, as it is in the lateral plane rather than the compression plane.
