Hotpoint 9926A
  • #17041
    clivejameson
    Fitted a new wash timer knob to one of these but it doesn’t line up 😯
    Were there any changes made to these?….serial number 68333674
    #172685
    Re: Hotpoint 9926A
    clivejameson wrote:serial number 68333674
    For date code 68 the correct knob for that is 1600014 😉
    #172686
    clivejameson
    Re: Hotpoint 9926A
    hmmmmm thanks Martin….thats the one i ordered, might be mis-packaged i wonder. I’ll order another one and let you know 😉
    #172687
    Re: Hotpoint 9926A
    The timer was turned 90° so that the wiring is underneath instead of at the side. I once had one of these that had been cobbled together from several different machines by some cowboy and bought by Social Services for a ‘Care in the Community’ house. No serial number on the new door trim. wrong control panel facia and no other ID. I finished up with three different knobs before I found the correct one. 😥
    #172688
    Re: Hotpoint 9926A
    I have sometimes separated the still good shaft gripping bit from an old knob and fixed it to the dial of the broken knob using small cable ties through holes drilled in the plastic. There are arrows in the plastic labelled A,B,C which make lining up easy.
    Mike.
    #172689
    johnnyj
    Re: Hotpoint 9926A
    Check the back of the knob there is an arrow which will point to various postions marked a,b,c etc if you have the wrong knob tease of the back of the broken one noting the position do the same with the new knob , superglue the good back onto the relevant position and your done, i only ever carried a 1 white knob and 1 brown used on any washing machine or washer dryer.
    #172690
    wilf
    Re: Hotpoint 9926A
    going back a bit but I did have a couple of knobs that were out of line by about 5 or 10 degrees put it down to faulty manufacture different batch was ok
    wilf
