HOTPOINT WD420 LIGHTS KEEP FLASHIN. DRY HIGH HEAT, REDUCE CREASE, TIME SAVER AND ON/OFF LIGHTS. :haier: ANYONE NO AS IT IS NOT IN THE ERROR CODES ABOVE. CHEERS
razor wrote:ANYONE NO AS IT IS NOT IN THE ERROR CODES ABOVE. CHEERS
Enough of the shouting (CAPS LOCK 😉 ) I know your tearing your hair out, but easy mate it’s only a Hotpoint 😉
No it’s not in the error codes as it means the main power module is not communicating with the programme module for some reason? (connection probs or component shorting out or some such 🙄 )
got it mate 😆 it was the stat on the outside the one you don’t need to strip to get to came loose. it reads f-13 on all other models wd860 as well we tried it and they all read the same. cheers for the help 8)
