Hotpoint Aqaurius FDW20 trouble fixing a blockage
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aqaurius FDW20 trouble fixing a blockage
  • #33175
    fraggle1984666
    hey i posted a few days back that i was havign some problems, ive just got round to opening it up and i have the top,front,foot and side panels all off.
    i can see into the bottom of the dryer and there are just a lot motors and tubes is there a way i can get through them all to check if theres a blockage ?
    right now i cant put my hand in in fear of breaking something.
    thanks for any help
    forgot to mention i can see in from the sides and the back ( a little bit )
    and when i feel the bottom of it theres water under the motors and pumps
    #237688
    Re: Hotpoint Aqaurius FDW20 trouble fixing a blockage
    Take the bottom off as well. The drain pump is the pink or blue block where the grey drain hose ends. Release one screw and it’s a twist fit from there.
    Stay safe, power off.
    fraggle1984666
    managed to get drain pump off ran garden hose through it to see if theres any blockages and there was.
    put dishwasher back together, tried a wash and it was going great filled up with water washed then all of a sudden jumped from wash to prewash
    which is from light 2 to light 1 from left to right and is just making a constant low rumble now :S
    #237690
    Has the base flooded? Constant low rumble could be drain pump running because the float switch is activated. Refitting pump can be a bit tricky…….
    fraggle1984666
    the pic above is what it looks like when the bottom is removed, when i removed the bottom water did come out which had been lying on the bottoms metal sheet.
    yh its a low rumble and is stuck on prewash flashing light and also salt indicator is on constant
    how would i go about fixing this on my own or is it a little too tricky for myself and would need a repairman ?
    thanks
    #237692
    Pump can be tricky to refit correctly. The O ring must be located correctly and all three lugs fully engaged before twisting the pump home. Perhaps a bit of obseerrvation with the side cover removed will reveal the leak?
