Hotpoint aqm8f49u comes up with error code f06 any idea wha this is or where can find all error codes for this types of machines as been getting loads just lately
Door lock fails to close / open, door lock PTC triac open/closed, Mains frequency signal fault, mains power signal fault.
– Check for water leaks that may affect connectors J004 or J11
(three-phase) causing the relative contacts to short;
– Check Door lock terminal board connections.
– Check J004 / door lock wiring;
– Check door lock;
– Renew PCB.
finally got round to looking at this machine, changed the interlock checked all wires and connections on board and only thing it does now is dry cant get the programme to work on anything else, wont spin, wash, drain etc only dry and ideas?
