Hotpoint washing machine fails to drain.
Drain pump found to be defective , circuit breaker tripped when it failed .
Pump replaced with known good one.
On a spin cycle the drum spins for a period before coming up with error code F011.
Checked drain hose from drum which is clear.
No blockage in hose for pressure switch. Pressure switch also changes continuity when pressurised.
No sign of damage on control board.
Any help appreciated
Many Thanks
