Hotpoint Aqualtis AQ113D697E
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Aqualtis AQ113D697E
  • #75755
    winker
    Went to this machine for getting stuck on wash.Heater o/c so replaced that.Set cycle but machine pumps and doesnt go to fill.
    Customer tells me then that he also had F05 on display which I think is timeout on fill which I can understand.Have done the procedure for emptying machine and putting 1 litre of water in machine as described by Martin.I still have the problem.Pressure tube is clear and has the linear pressure switch.Have done a physical on the power module and looks ok.Was going to order new switch but wondered if there is anything else i have missed.
    Is there any service info available,does it need resetting.
    Any help welcome.
    steve
    #396028
    neilsukwg
    Re: Hotpoint Aqualtis AQ113D697E
    Try EMW for advice and a possible remedy
    01159652118
    #396029
    winker
    tried that there not even on them yet
    #396030
    a1al
    Try resetting the machine, the procedure is listed in this forum near the top, F05 is pressure switch stuck or blockage in sump hose or pump.
    #396031
    johnnyj
    I had one today reprogramed the board, fixed it.
    #396032
    jason1970
    Out of interest, how did you reprogramme the board? Thanks.
    #396033
    jason1970 wrote:Out of interest, how did you reprogramme the board? Thanks.
    Have you not heard of a Hardware Key and Smartcard then?
    #396034
    I don’t think that johnnyj needs those. 😉
    #396035
    winker
    looking for indesit or hotpoint engineer close to gu478qu who can help pm please
    #396036
    jason1970
    Yes, Martin. Heard of those. Also heard how unreliable they are? I was just wondering what method Johnnyj had used. Think Winker has the best idea, get a friendly Hotpoint/Indesit guy on the case!
