Hotpoint Aqualtis AQ113F4971 No Power
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Aqualtis AQ113F4971 No Power
  • #93903
    Bigangel
    I ask for some help, I have the above machine, will not power up! before it went dead the door lock mechanism clicked on/off for a few times then the machine worked for an hour and then nothing.
    Reading posts and internet searches I have done the following;
    Power is coming into the compressor located at the top.
    Door switch has an ohms of 1800 when my meter is set at 200.
    Wires to the front panel via the hinge have not become damaged.
    Door PCB looks good and the power micro switch on the board clicks.
    Not yet disassembled the main module.
    #455873
    1totalshambles
    Re: Hotpoint Aqualtis AQ113F4971 No Power
    Compressor, you mean suppressor. At a guess you could get lucky and it is still the door lock. However, given the rather suspect pcb components on these things, I would look at first is the 3 phase power pcb. If lucky you may see where it has failed = blown component = so you`ll at least know and this will be dealer only repairable at great expense unless under parts warranty! If any tracks on the board are blown something caused it and it could well be the door lock that did just that.
    Power off at all times. Becareful as the power pcb packs a punch even if power is turned off so wait 20 mins before handling to allow the capcaitors to discharge.
