hotpoint aqualtis AQ9F49 UK V
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint aqualtis AQ9F49 UK V
  • #68137
    tash
    went to above machine last week cleared sump when not draining..tilted machine back to clear blockage and now even though it drains ok it wont fill and the door remains locked unless manually released.. did the reset procedure but made no difference. ive ordered a new pressure switch assuming its stuck on full..would tilting cause damage…thanks
    #369970
    jimca007
    Re: hotpoint aqualtis AQ9F49 UK V
    They do seem to be easily damaged but the last one I had I cut the cap off and adjusted down the plunger screw till it filled and then turned it back up. I know they tell you not to adjust them … just figured what can you loose if the alternatives replacing it with a new one anyway !
    #369971
    A1engineer
    last one i had ended up getting new board to sort it, apparantly theres a firmware update on the boards :nono:
    #369972
    tash
    just an update for info..fitted new switch..didnt seem to work…but 30 minutes and 5 resets later it all started working ok..didnt fancy trying old switch again so left it on..
    #369973
    I don’t know if THIS PROCEDURE applies to Aqualtis models….??
    Perhaps Jim can confirm? 💡
    #369974
    tash
    yes it does.. that’s the procedure I did it didn’t work first time
