judders as turns and seems loose at front.
Tear drop bearing and shaft ok. Also drum wheels seem ok.
Is there other support in front apart from wheels that could have worn and if so what is part no.
Mike 😕
boselecta wrote:seem to remember they were advising to remove the front 2 wheels that are prone to noise and replace them with the 4 drum front plastic bearing pads.
That was on much earlier models, the wheels have been reintroduced on the recent ones, certain serial numbers have had noise problems, hence Bobs post. 😉
PM’s or private messages, I sent you one on the day of your first post asking you to reply to my PM with an e-mail address so that I could send you some info.
Go to your User control panel to check your PM’s you should have it set to notify you of any PM’s.
