Hotpoint Aqualtis AQCF952BS(UK) F10 error
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint Aqualtis AQCF952BS(UK) F10 error
  • #99977
    Llyndonium
    The heating elements had broken in our tumble dryer. I have two new element units complete with thermostats. One of them has an open circuit on the one-shot thermostat, the other is a closed circuit.
    If I run the ‘closed circuit’ element, the dryer runs but does not heat.
    If I run the ‘open circuit’ element, after a few seconds, I get a flashing F10 error.
    I have checked connections etc and a few different options, including the old thermostats but I can not work out what the problem is.
    Please can someone offer some advice? I have a multimeter if I need to check continuity or resistance.
    Thank you!
    #478734
    when you tested it did you put wet clothes in
    a lot of dryers keep the elements off until moisture is detected
    Llyndonium
    Yes, I used wet clothes just in case.
    As I understand it, the white ‘one shot’ thermostat has to be an open circuit. So it follows that the F10 error is what I am trying to fix. I found a service manual for a similar model and it states the following for F10:
    F10 ​​​​​​Open circuit in the heater. Common wiring.
    • Check the wiring between the cycling stat and the
    module;
    • Check wiring between module connector J4 and the
    heater;
    • Test heater elements.
    Note:- Frequent cycling stat operation can cause F10,
    check filter and condenser for blockages. The module
    checks and waits 3 times before displaying F10.
    I have continuity on all the wiring of the loom on the heating unit (when it is unplugged) but can I check the outputs on the pins of the J4 connector? Is there a safe and proper way to do this?
    #478736
    the way it reads is its unlikely to be the element
    the module is sensing the element and if its open circuit it will give you F10. Also its saying if the unit overheats and trips the stat a lot it can trigger F10 but yours is not heating at all
    Llyndonium
    OK, I’m going to have to call time on this. It’s going to the dump haha!
    I either get the F10 with the correct one-shot thermostat or no errors with no heat. I’ve had the board off and cleaned it out along with all the connectors etc., but to no avail.
    Any last-ditch attempts I can make before I load up the car?
    #478738
    how old is this dryer ?
    Llyndonium
    Build date of 2010, so I can’t complain really…
    #478740
    ok a lot of these were on recall was yours modified ?
    Llyndonium
    Yes, I believe so. I have a green dot on the back
    #478742
    pity
    if it was not done they would have given you a new dryer
    was worth a shot
    Llyndonium
    Thank you for the help anyway Dave. New dryer it is!
