I’ve had a board returned from EMW and display is now showing F18.
It will fill to first level then abort before next fill level and drain out.
Set on spin with drum empty of clothes and water it will start to pump then abort before motor kicks in showing F18.
I have meggered everything pinched connectors to board, checked for blockages and changed pressure switch.
Does anyone have a wiring diagram so I can double check connections to the board are correct?
Suggestions on anything else I could check would be welcome
