Hotpoint Aqualtis AQGL129PM.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Aqualtis AQGL129PM.
  • #59859
    TheSpinDoctor
    Hi all.
    Some advice/info please chaps. I usually work on Lux appliances but I have a friend’s sister who has one of these, apparently 2 years old.
    Symptoms are apparently that it will do the wash fine but on the final spin it just drains & then all the lights flash.
    Is there anything that I should be looking for with these symptoms. I thought brushes unlikely with a 2 year old appliance but anything is possible.
    Is there a diagnostic cycle? If so, how is it entered? Are there any fault codes that may help? Any info whatsoever greatly appreciated guys.
    Thanks in advance & Happy New Year to you all.
    TSD.
    #339851
    Re: Hotpoint Aqualtis AQGL129PM.
    Brushes very unlikely. 😉
    Sent you some light reading. 😉
    TheSpinDoctor
    You are a gentleman Jim.
    As I see this has a 3 phase motor I have to agree that brushes are at best unlikely. To be fair, I haven’t seen it yet.
    #339853
    TheSpinDoctor
    Righto. Been & looked at it & turned out to be a blocked drain filter. Unfortunately, the filter is broken & it is now leaking from the join of the filter & the pump housing. Can I get the filter & Gasket alone or is it only available with the pump? Part numbers & rough prices apprieciated.
    Thanks.
    #339854
    Pump complete is C00145315, list around £20 ex vat, quite a bit less at Masterpart. 😉
    Filter, filter handle and filter seal all available but my guess is they won’t be stock items so a delay in obtaining them might be likely.
    Filter alone is listed at nearly £10 ex vat.
    Filter C00141034
    Handle C00045023
    Seal C00045025
