Re: Hotpoint Aqualtis AQM8F49I Washer Dryer F13
F13 = Dryer NTC open or short circuit.
Check efficiency of contacts on connector J011 (commutator motor fitted) or
J14 (three-phase) on PCB;
– Check NTC impedance value on wiring connectors J011
(commutator) or J14 (three-phase) between pin 1 and pin 2.
The impedance value at ambient temperature (20°C) must be
approximately 20 KOhm;
– If measurement is incorrect check NTC wiring;
– Check the same parameter directly on the NTC (20 KOhm);
– Renew NTC;
– Renew PCB.
