Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Aquareius DF61 – not filling
- This topic has 3 replies, 4 voices, and was last updated 21 years, 1 month ago by
way2larj.
February 14, 2005 at 10:13 am #7934
way2larj
ParticipantHi – our DF61 is not filling – it’s about 5 yrs old – check the water inlet pipes and pressure – all fine, so it is with the washer itself. It’s got a dial on the front to start the washcycle. When it’s in the OFF position, I can switch the power on button ON, and it will try and start immediately before the dial is moved to the ‘Start’ position for the washcycle – strange. It makes pretty normal sounding whirring noises (i.e. not totally silent), it will drain – I put a bucket of water inside and it was drained out – so it seems to be able to perform the draincycle, but you cannot hear water entering – the washcycle just stays on the ‘wash’ bit, and when you look inside, there is no water coming in at all. Checked the inlet filer on the inlet port at the inlet hose connection, and that is clean. The outlet filter in the base of the interior is clean also. The spray arms appear to be free from blockages.
When first noticing the problem, the washer had been on for about two hours or so, and there was an unusual smell – don’t think it was an electrical burning-type smell, but it was distinct – this was still when it was on the ‘wash’ bit of the washcycle (since it doesn’t get beyond that).
Guessing it might be the solenoid valve. Think the pump is working since the washer makes whirring noises when switched on (i.e. not totally dead).
Appreciate any thoughts. How much is a solenoid valve and how easy is it to fit ? Any pictorial walkthrus on the Net showing replacement of a solenoid valve (for this or any other washer ?). Thanks.
February 14, 2005 at 11:03 am #126028Dave_Conway
ParticipantRe: Hotpoint Aquareius DF61 – not filling
It may be the valve (£33.09 inc VAT plus £3.50 postage).
There are no instructions available anywhere though I’m afraid.
It may well be something else as well, I would recommend an engineer calls and diagnoses for you.
Have a look at repairs@ and the directories for one near you 😉
If you are tmepted to look, please pull the plus 1st :zap:
February 18, 2005 at 7:59 pm #126029admin
Keymasterhotpoint DF41 dishwasher.
fills ok and heats up but refuses go to washing cycle,then beeps and lcd shows ‘error 10’.Can anyone help please?February 18, 2005 at 8:08 pm #126030Martin
Martin Ic,
In actual fact it refers to a ‘fill error’ and not a big problem for an engineer to sort for you. Just pop in your details in our repairs@ for a local engineer to take a look for you 🙂
