hotpoint aquaries wma54
  • #73804
    i=p/u
    hi just bought one of these machines second hand and once you set a programme it fills then just stops and flashes on pre wash… now according to manual it means not enough water, so any advice on where the problem ly’s. ty
    i can take it back but wait to see if i can diagnose the problem….
    #388855
    Muv
    Re: hotpoint aquaries wma54
    Check your water inlet hoses for any kinks, also check inlet valves filter..that may be clogged up
    Have you connected it to both hot & cold ?
    #388857
    i=p/u
    yes connected hot and cold, from reading through site, inlet valve is only thing standing out… will i find this at the rear, under the hood, where pipes are connected too…
    what a day…. cheers…. ty
    #388858
    Yes, double cold, single hot.
    #388859
    i=p/u
    i just had inlet valve off and they are stiff, but can be pushed with finger , but dont spring in and out,
    ialso found clear tube from back of soap tray was disconnected to circle component, probably happened in transit, put it back on now anyway
    #388860
    i=p/u
    i also have inlet valve off and they seem stiff, is this normal..? ty
    #388861
    No idea what you mean by ‘valves feel stiff’??????
    Drain it out completely and try again, the plastic pipe is the pressure hose, ifithas come off the pressure switch you will get the error message you did.
    #388862
    i=p/u
    so far so go iadom, it looks like it was the clear pressure hose. ty.. it has now used all my hot water for dishes lol. what happens if their is no hot water , will the programme stop, has this machine no heating element, are these old machines? if you have the time
    have you certain procedure you follow when working with appliances?
    isit years of expierience along with customer telling you whats not working, or isit i.e washing machine broke can you fix it and whats your methodical approach ….
    #388863
    If it has used all of your hot water it suggests you may have connected the pipes to the wrong valves, hot pipe to cold valve etc. if you have disconnected any wiring then you could have replaced them on the wrong valves. If you set it to a rinse & spin programme it should only fill with cold. All washing machines have a heating element.
    There is no magic formula but over 40 years experience does help at times.
