Hotpoint Aquarius 1100 WD61x
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Aquarius 1100 WD61x
  • #63965
    crockett
    The washer dryer im repairing was tripping the consumer unit the problem was a faulty armature whichI replaced.Now the machine works perfectly but dosen’t heat properly (intermittently and only at 40* settings) the element is good, the thermistor is ok,the pressure switch is working, the cables are all conected and good and the board is not showing any damage.Its an old model and the timer searches until it gets to the 40* programme and then heats intermittenly.
    Can anyone out there help me please.
    Thanks,
    Crockett.
    #355677
    Re: Hotpoint Aquarius 1100 WD61x
    Can only be a faulty control unit given the sypmtoms you describe.
    #355678
    crockett
    Thanks iadom taught that would be the case but I was hoping it could be something else,thanks again,crockett.
    #355679
    Have a look at http://www.emwelec.co.uk to see if they do a recon timer.
    Mike.
