Does anybody know where I can get hold of a technical guide for a Hotpoint Aquarius 1100 WM63. I have replaced the Solenoid and not totally confident the connectors are in the right place.
Manuals are copyright protected and not readily available.
Which solenoid did you replace, the hot or cold?
At least one wire is a link between the double valves, also if the wires are all black then if you look closely at the wires near the ends you may see hot, cold etc written on them to help you identify them.
It was the cold double solenoid. it has three wire with a cross over. The cables are marked i believe as cold, neutral and fabric I believe. Just need to check I put them back in the same place.
If you follow the rubber pipes to the dispenser you should be able to tell which hose is going where by looking at the top of the dispenser. The neutral link goes to both valves, the ‘fabric’ to the conditioner container and the ‘cold’ to the other one. I think you will find that the fabric valve runs into the front of the drawer and the cold one to the rear.
