Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint Aquarius Condenser Drier – Possible Sensors Issue
- This topic has 11 replies, 2 voices, and was last updated 4 years, 2 months ago by
LouFromWales.
January 8, 2022 at 4:04 pm #100432
LouFromWales
ParticipantHi
How does Ready to Wear and other settings work?
When I use these the drier will randomly stop and beep.
I don’t know if this is because there are sensors which possibly have lint or fluff on or if there’s a common issue ?
January 8, 2022 at 5:05 pm #480591electrofix
Moderatorcoomon issues on these is poor maintanence as the condensor is hard to clean properly
January 8, 2022 at 5:15 pm #480592LouFromWales
ParticipantIts not that hard to clean lol
January 8, 2022 at 5:24 pm #480593electrofix
ModeratorLouFromWales wrote:Its not that hard to clean lol
compared to other its difficult. you should see some of the ones i have to unclog
dave
January 9, 2022 at 7:39 pm #480594LouFromWales
ParticipantI wipe inside the drier where the condenser sits so I get most of the fluff and put the condenser unit in the shower.
I’ve also tried to put my hand/arm inside round the bend at the back. Is there a common place on the Hotpoint aquarius where there might be fluff somewhere? How do the sensors work? Where are they?
Ta
January 9, 2022 at 9:49 pm #480595electrofix
Moderatorhave you looked through the condensor with a torch to make sure its clear front to back ?
have you looked at the fluff filter to make sure its not clogged, hold it up to the light and make sure its clear
January 9, 2022 at 9:52 pm #480596LouFromWales
ParticipantYes, I thinking if taking the pump and float switch apart? Could fluff get there? Ta
January 9, 2022 at 10:04 pm #480597electrofix
Moderatoryes but then you would get a container full light even if the draw is empty
January 10, 2022 at 9:58 am #480598LouFromWales
ParticipantI took the float switch and pump apart. There was a little fluff there which I’ve cleaned. There was some water in the reservoir but not enough to set off the float switch. Should this be dry or is some water normal?
After a good clean it still only runs the Settings like Ready to Wear for a few minutes.
I still have the 90 and 60 minute settings. What bugs me is 60 isn’t quite enough, 90 is too much hence why I’d like the interactive Ready to Wear setting back.
Ta
January 10, 2022 at 10:04 am #480599electrofix
Moderatorthere is always water in the bottom of the pump chamber
some dryer ( cant remember about hotpoint) have an ability to alter dryness levels
check in the owners manual and see if thats an optionif no am going to need full model and commercial codes to look anything up
January 11, 2022 at 9:38 am #480600LouFromWales
ParticipantRe-reading the manual it sounds like the tumble drier is intelligent enough to dry at a duration to suit the clothes. The manual gives times for each program but also states they may take longer with a maximum of 5 hours so therefore its clearly suggesting the machine has the ability to detect the dryness of clothes.
Looks at the machine I can’t see any sensors or wires at the area of the condenser bottle, there’s nothing around the condenser unit and in the rear chamber just a small pump and float switch?
I can’t see where else there could be anything??
January 11, 2022 at 10:07 am #480601electrofix
Moderatorthere are 2 ways of sensing dryness
1 damp sensor, a metal plate in the drum the the wet clothes touch
2 a sensor on the heater and another at the at the front normally where the filter comes out. hot air enters the dryer at a given temp, goes through wet clothes which cools it and exist the drum over the second sensor. the temp difference is how dry the clothes are
