Hotpoint aquarius condenser dryer tdc32p
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint aquarius condenser dryer tdc32p
  • #99754
    Valleyboy22
    Hi everyone
    Can somebody tell me the correct way to check the heater out with the multimeter, iam getting readings not sure if am right.
    Still trying to figure out why I am not getting heat, is the relay an issue as well as the timer not sure how to check these out with the meter.
    When checking the stat inside above the door can you check it in place or does it have to be taken out. I know the machine is old 2003 I would like to keep it going it has been a good servant i know some of the parts are probably obsolete now.
    Regards
    #477781
    Is this a wind up? This the 3rd or 4th separate thread you have started on this topic, you have had numerous replies. You have been told that from your previous readings the heating element and the stats are almost certainly ok. You have also been told the relay is not involved. It has been suggested that the fault may lie in the control timer, something that really needs a wiring diagram to check fully. However you have also been advised that the control timer has been obsolete for some time.
    If you have further questions you should always add them to your previous thread, not keep starting a new one.
