hotpoint aquarius condenswer dryer CTD00G
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum hotpoint aquarius condenswer dryer CTD00G
  • #79968
    mikey66
    Working but tripping out main fuse box now after cleaning out fluff etc- not sure what the problem is as it didnt trip fuse box out before!
    It was leaking water and probably some water reached the electrics when it was on its side being cleaned.
    So I took back and top off and dried out with hair dryer – dont know what else to try, the rear heating elements look a bit delicate but they were heating and all was working before I messed with it !
    Any expert advice would be appreciated thanks :boops:
    #411225
    Re: hotpoint aquarius condenswer dryer CTD00G
    You could try drying the heating elements themselves with your hair dryer but TBH you need a megger or at the very least a decent multi meter to check the insulation of all components.
    #411226
    mikey66
    thanks for the suggestion but wouldn’t know how to use it !
    #411227
    Then you should not be attempting to repair electrical appliances full stop.
    #411228
    mikey66
    Thanks for the useless advice
    #411229
    mikey66
    Suggest you close down this useless web site that can’t give sensible suggestions
    #411230
    And I suggest you read the Forum rules before you do yourself serious injury or worse. 😉
