Re: Hotpoint Aquarius – Conditioner problems
This can be caused by using a conditioner that is to thick, poor water pressure or sometimes by careless filling of the soap powder, ie pouring it in and getting some into the fabric conditioner compartment. Also depending on which model you have ( you didn’t say) 😉 you may have the drawer set for liquids whilst using powders. This can cause the powder to splash over into the conditioner compartment and will block it very quickly.
If the type of conditioner you use is on the thick side then water it down a little before use or switch to a different brand that is more fluid.
