Hotpoint Aquarius DF22 runs all day!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius DF22 runs all day!
  • #35036
    seanory31
    This machine will run all day unless the timer is helped on. It sticks between programme 3 & 4 and again between 4 & 5.
    Recently 2 engineers have looked at it. All wiring was checked and a new timer and heating element was fitted but its still the same. I would dump it it only my elderly mother will not except a new one !!
    ref Hotpoint Aquarius DF22
    #244904
    Re: Hotpoint Aquarius DF22 runs all day!
    If it runs all day but does not heat up or boil then the heater is not working.
    It is very unlikely that both the timer and heater would fail at the same time. In fact the only heater I ever changed in one of these had been worn away by the lower spray arm, very rare for them to fail.
    By far the most common cause of no heat is a small break in the wiring harness, at the point where it goes under the door.
    Whilst not wishing to denigrate anyone I think you need a second opinion. 😉
    TBH I had to write one of these off today, the whole of the wiring harness had become brittle and had several breaks, I did repair it in this area about five years ago but it is to far gone now and a full harness is not now available. 😥
    seanory31
    iadom wrote:If it runs all day but does not heat up or boil then the heater is not working.
    Thanks Jim
    There is no problem with the heating. In fact it washes great. I think the engineers were trying to fix it by process of elimination!!It seems to me that the timer just sticks. The old timer did exactly the same. I wonder if it is wired properly!
    #244906
    Not that many wires to get wrong. TBH I would be a little wary of someone who changed a heating element on the off chance it might fix the fault, most element faults are fairly obvious.
    When it sticks is it actually doing anything or does it just stop with a faint buzzing noise?
    seanory31
    iadom wrote:Not that many wires to get wrong. TBH I would be a little wary of someone who changed a heating element on the off chance it might fix the fault, most element faults are fairly obvious.
    Hi Jim
    It keeps running and I usually click it on maybe 2 clicks and then it completes the wash to between 5 and dying mode, then I have to click it on again. Would something be hindering the timer from going around.
    It does wash the dishes well but you have to sit with it. Sort of defeats the purpose of having a dishwasher.
    #244908
    If the fault is exactly the same with the old and new timers then it would suggest that they are not the cause of the fault, unless the wiring was tampered with before the first timer was changed. The later timers supplied to these are from a different manufacturer but the terminal numbers are the same, just in a different position. There are only about ten connections to change on these timers.
    If you are absolutely certain that it is filling, washing & heating correctly then
    it really needs an engineer with a timer sequence chart to determine exactly what components are involved when the machine sticks.
    When you click it into the drying cycle does it complete the full drying cycle or do you have to click it to the end?
    This machine is technically a very simple machine as dishwashers go, but from this distance there is only so much guess work that one can do TBH.
    #244909
    seanory31
    iadom wrote:If the fault is exactly the same with the old and new timers then it would suggest that they are not the cause of the fault, unless the wiring was tampered with before the first timer was changed. The later timers supplied to these are from a different manufacturer but the terminal numbers are the same, just in a different position. There are only about ten connections to change on these timers.
    Hi I always have to click it on to the endin order to finish drying cycle!!
    #244910
    That suggests a faulty timer, no other components involved to ‘hold’ the timer through the final drying stage.
