hotpoint aquarius df61p problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum hotpoint aquarius df61p problem
  • #77722
    len67
    Hi could someone please advise me, I’ve had my hotpoint Aquarius for years with no problems, but the other day it tripped my fuse box and now the mains on/off switch won’t stay in and the mains light won’t come on, if I keep it pressed in then the dishwasher works and I’ve gone through the cycles which seem fine so do you think I need a new on/off switch or is it something else, many thanks for your help.
    #403187
    Re: hotpoint aquarius df61p problem
    It could be a number of things the most likely of which is a faulty heater or circulating pump. In any even it needs checking out electrically with an insulation tester to find the source of the residual earth leak. You had best call in a local expert for that.
    #403188
    len67
    Thanks for the reply martin, im not sure whether to bother getting it repaired as its getting on a bit, would you have a rough idea on cost of repair compared to buying new, many thanks.
    #403189
    Not a clue I’m afraid, bit like “how long is a piece of string?”
