hotpoint aquarius door won’t open
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint aquarius door won’t open
  • #8261
    My machine reached the end of the spin cycle but I can’t get the door open. I have tried several times to let it run to the end of the cycle but still no go,
    Any ideas?
    #127686
    Re: hotpoint aquarius door won’t open
    There are several versions of the Aquarius range and have differing door locks 😕
    Try lowering the drain hose into a bowl or bucket to drain every last drop of water out, then try the door again. 😉 If it has a release device on the door and it is loose to operate…then you’ve broken it and you need an engineer in to sort it. If it has a push button on the front fascia and it doesn’t engage, then either that too has broken or the machine still has water in it, drain it first then try again 😀
    Failing all that please give us the model number for further help :tup:
    It’s a Hotpoint Aquarius 9926 washer drier.
    The catch on the door has some resistance and doesn’t feel broken.
    I have lowered the hose as suggested and only got about half a cupful of water out. The catch will still not release
