Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Aquarius DWF 30 Dishwasher Advice
- This topic has 8 replies, 3 voices, and was last updated 18 years, 5 months ago by
ceedy.
October 31, 2007 at 11:23 am #31825
ceedy
ParticipantHi,
Our Dwf 30 which is now about 4-5 years old and has never put a foot wrong has suddenly stopped.
it was about halfway through the washing cycle ( the tablet had been dispensed) and it just stopped .. no real noise, no smoke nothing..
now its completely dead.
Power is going through the power switch. but theres no activity. no lights nothing.
Can I get a wiring diag somewhere to trace it though ??.Anyone got clues where to look.. it has a seimens module.
Is there any monitoring of other parts like a heater element etc.. that can cause it to shut off ??…
we always used Oost type stuff etc to keeo it clean inside and its still looks like new..
Any help please ?? thanks Chris
October 31, 2007 at 5:29 pm #232631iadom
ModeratorRe: Hoppoint Aquarius DWF 30 Dishwasher Advice
A Bosch made machine, no wiring diagrams available I’m afraid. Live testing is not advisable. If you have a circuit tester you could see if you can find a trace into the module from the door or On/Off switch. Module is very expensive and indeed is obsolete for some models already. We would need your full serial number to be sure.
November 2, 2007 at 9:51 am #232632ceedy
ParticipantRe: Hoppoint Aquarius DWF 30 Dishwasher Advice
iadom wrote:A Bosch made machine, no wiring diagrams available I’m afraid. Live testing is not advisable. If you have a circuit tester you could see if you can find a trace into the module from the door or On/Off switch. Module is very expensive and indeed is obsolete for some models already. We would need your full serial number to be sure.
Hi again ,
thanks for the supply.
The module number is Siemens 5WK57751..
My wife called in local repair man while i was at work ., ( not my choice) ?. he spent 1 hour (£44) to tell us what I aleady knew theres power into but not out of the module, and that would be 200+ ? for a new one if one can be found .. or 84 for a repair that might sort it out.. thats 84 quid even if it can’t be repaired or its not the module thats the problem?. … we declined the offer. 200 quid??? pass the lube !!! 😉
Actually it only measures 125 volts from the power switch to the module , according to my Fluke meter.. so off to have a track of the power feed in from the plug. module looks to have been a bit warm (slight dicolouring of the case around the black transformer ??) but little or no continuity through the transformers?? 8 pinouts..regards
ChrisNovember 2, 2007 at 10:21 am #232633iadom
Sorry, I meant the serial number of the dishwasher.
The list price of the module that is still available is just over £100 ex vat.
November 2, 2007 at 10:34 am #232634ceedy
iadom wrote:Sorry, I meant the serial number of the dishwasher.
Thanks again for a quick reply…
Where will I find the serial ?.. this machine is quite naked of any numbers/ labels etc externally .. the only number I can find is on the mains cable input plastic fitting ..
regards
Chris
November 2, 2007 at 10:40 am #232635iadom
Serial number is usually along the top edge of the cabinet just under the lid or etched into the stainless steel door along the top inner rim.
November 2, 2007 at 10:51 am #232636ceedy
iadom wrote:Serial number is usually along the top edge of the cabinet just under the lid or etched into the stainless steel door along the top inner rim.
Coo right in front of me ?!!!!..
the numbers on there are : Model DWF30P/17 , TYP S9HIH , 03702447,
SESHPF5GB and 10203280226189470142…any of these ok ???
best regards
ChrisNovember 2, 2007 at 11:15 am #232637Martin
ceedy wrote:Actually it only measures 125 volts from the power switch to the module , according to my Fluke meter.. so off to have a track of the power feed in from the plug
Smacks of a supply problem to me? 😕
You should have 230/240v at the main on/off switch so I suspect wall socket, 13amp plug problems or even the Mains Filter Unit?
November 2, 2007 at 4:49 pm #232638iadom
ceedy wrote:03702447,
That looks like the one, date code 03 changes every month, sadly the modules for machines before date code 07 are now obsolete.
Jim
