I have the above dishwasher and recently it’s stopped filling with water.
I had the machine out the other day and there are no kinks in the pipe etc, and after some fiddling managed to successfully run a rinse programme. However on completion of the programme it is failing to load any water again.
The supply is fine, and the internal hoses must be fine as it ran a wash ok. When it tries to load water there is a clicking noise which seems to come from the water inlet valve. I’m assuming it’s this valve that is faulty but before I replace it wondered if this is a common problem, or am I barking up the wrong tree?
Any advice would be appreciated.
Thanks.
