Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Aquarius FDD914G.R drain pump running
- This topic has 13 replies, 2 voices, and was last updated 5 years, 9 months ago by
Phoenix126.
June 26, 2020 at 5:24 pm #97905
Phoenix126
ParticipantThe drain pump constantly runs ending in an A:3 error which I believe is a drain time out.
I’ve seen many people with the same fault and I’ve already replaced the float switch in the base.
I’ve taken off the left side panel but the layout is nothing like any troubleshooting videos I’ve been able to find.
Before I fork over £35 for a replacement fill hose, is there anything else I can check?June 26, 2020 at 10:42 pm #470055electrofix
Moderatorwhy are replacing a fill hose when it seems to be a pump problem ?
an error 3 is the pressure switch has failed to reach empty in over 8 mins
May just be a faulty pressure switch or a blocked hose to it
June 27, 2020 at 12:46 am #470056Phoenix126
ParticipantCould you advise where the pressure switch is located? Is it reasonable easy to replace?
June 27, 2020 at 8:38 am #470057electrofix
Moderatorot sure where it is but it should not be hard to find. there will be a thin plastic tube coming out of the sump of the machine which goes to it. the tube sends air pressure generated by the amount of water in the machine up to the switch
check the tube going from it for blockages, you can blow down the tube into the sump but unless your switch looks like the example below dont blow into the switch. Later switches are a different design and can be damaged by blowing into themDave
June 27, 2020 at 10:56 am #470058Phoenix126
ParticipantThanks. I’ll check.
June 27, 2020 at 3:35 pm #470059Phoenix126
ParticipantOk. Found that pulled the pipe off and poked a cable tie up it. Reconnected it and now the machine starts a cycle, fills but comes up with A:5 as soon as it starts draining.
June 27, 2020 at 3:48 pm #470060electrofix
Moderatorthat another pressure switch error code
try
turn off power
take off the tube to the pressure switch from the pressure switch end or disconnect from the sump end and find another peice of tube to connectadd about a litre of water then suck and blow tube to clean it out
mop out water before reconnecting tube
June 28, 2020 at 2:30 pm #470061Phoenix126
ParticipantOk. I removed the right side panel so I could access the pipe, removed it and flushed it then replaced it. Cycle starts, machine fills and drains but gives the A:5 error again.
June 28, 2020 at 2:36 pm #470062electrofix
Moderatorcheck the switch wiring back to the board, make sure no wires have broken
after that its down to
air leak in the pressure circuit which incluses the pipe and the switch diaphram
the switch its self contacts dirty or sticking
or the board not recognising the instructionDoes you switch look like above ? if yes it can be tested with a meter
June 28, 2020 at 2:56 pm #470063Phoenix126
ParticipantNot exactly but very similar.
June 28, 2020 at 3:03 pm #470064electrofix
Moderatorthe later one normally have very small cables going to them in a multiplug so if it has the same large terminals it should be ok
the early ones you can blow into them and the contacts will click. then you can check continuity with a multimeter to see if the contacts are making
it also means with the machine turned off you can add water to the machine till the contacts click to make sure its operating. proving the pressure circuit and the switch
June 30, 2020 at 3:26 pm #470065Phoenix126
ParticipantProblem solved. I’m an idiot as I was testing with the drain hose at floor level because I didn’t realise it had to be raised above the sump.
There had been a genuine problem because the error originally occurred while the machine was plumbed in, so I guess the replacement float switch or clearing the pipe to the pressure switch did the trick.
Thanks for your help, it’s much appreciated.June 30, 2020 at 3:45 pm #470066electrofix
Moderator” Machine ok Owner Faulty” lol
June 30, 2020 at 4:05 pm #470067Phoenix126
ParticipantA classic case of operator error.
