Hotpoint Aquarius FDF784
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius FDF784
  • #88679
    Jonbaron
    My dishwasher flashed up error code A 13 briefly on Saturday. I tried to reset it, and now it comes up with fault code A12. Even if I shut the power off, it automatically comes up with the code. Does anyone have any experience of this. I bought the machine second hand, and am wondering if it is worth repairing, or if I should just simply replace it. Thanks
    #438966
    Re: Hotpoint Aquarius FDF784
    Both codes relate to an electronic fault. A12 is a communications error so it could just be loose or broken wiring contacts or plugs, possibly disturbed in transit. check the connections between the main pcb in the base and the console pcb.
    Worth noting that the main pcb in the base has to be programmed if replaced and the whole of the console assembly including both modules is one very expensive unit. 🙁
