Hotpoint Aquarius FDM550 not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius FDM550 not draining
  • #84089
    mr.stevie.rogers
    I have a 5 and ahlf year old hotpoint aquarius dishwasher model number FDM550/FDL570
    195067016.00
    It has stopped draining the water and now will not work at all. When I turn it on the green ‘on’, orange ‘tabs’, green ‘start’ and orange ‘wash’ lights stay lit (not flashing) and it does nothing at all. I have checked the filters but they are fine. I think the pump may be blocked but don’t know how to fix it. Any advice appreciated please. Thanks in advance
    Stephen
    #424691
    Re: Hotpoint Aquarius FDM550 not draining
    Drain pump is accessed by removing the base plate. Remove mains plug, get as much water out of it as you possibly can and carefully lie on its back to get at the base plate.
    #424692
    mr.stevie.rogers
    Thanks I have accessed the pump now but it is locked in and I can’t remove it. I removed 4 screws which have a black rubber tube attached at the top of the pump. But the pump also has another thicker black rubber tube to the right attached not with screws but with a metal band which I can’t easily remove. See https://www.dropbox.com/s/pprmkxowe0nx1 … 7.jpg?dl=0
    Any further suggestions much appreciated.
    #424693
    Sounds to me like you are trying to remove the main circulation pump and not the much smaller drain pump which is a twist fit. Follow the grey plastic outlet pipe into the machine to find the drain pump. 😉
    #424694
    mr.stevie.rogers
    Thanks I have found the drain pump now but did not find any obvious blockages. Although the pump itself is full of water – is that normal?
    https://www.dropbox.com/s/g32agcexfjul2 … 5.jpg?dl=0
    #424695
    Water in there is normal.
