Can anyone help?
My fast and delicate lights are flashing (lights 4 and 6 when counting from the left – not including the rinse aid light)
On any wash setting the cycle starts and then after about 30 seconds both the above lights come on – the cycle continues for another 30 seconds or so while the water is drained away – is the water supposed to be cold at this stage or would it be expected to be warmish?
I then need to switch power off to do anything else!!
I have checked and cleaned the visible filters but not sure how to get to the pump to check that – can someone give me a starting point?
This is driving me nuts now as with 4 boys to feed there is lots of washing up generated!!! 🙁
Help!!!
Neons 4+ 6 indicate a heater related fault. The heating assembly is a known weak point on these Indesit machines. The only way to be certain is to check all the components involved with the correct test equipment.
Please remove the mains plug if you intend to proceed or try the link below to see if we have someone who can help.
