Hotpoint Aquarius FDW60 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius FDW60 dishwasher
  • #70650
    mints
    When using the fast wash prog. the machine fills then leds 3 and 5 eco and prewash flash and the machine emptys.
    When trying again it usually washes without any problem, just now and again it may require three atempts.
    If the normal prog. is selected there is no problem at all, it seems to be just the fast wash.
    #378608
    Re: Hotpoint Aquarius FDW60 dishwasher
    3+5 = blocked filters.
    Mesh plate, filter or microfilter, pressure
    sensor, pressure switch, circulation motor.
    Have you tried a dishwasher cleaner through it?
    #378609
    mints
    Yes I have had a cleaner through it and made sure the filter is clear and clean.
    I know this error code can indicate a ciculation pump problem but as it operates on the normal prog. without hesitation it seems it is the fast prog. not turning pump on every time or is there a senser coupled with the faulty fast wash that could cause this.
