Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Aquarius FDW60 Dishwasher
- This topic has 7 replies, 3 voices, and was last updated 13 years, 2 months ago by
bobmaryann.
February 5, 2013 at 4:39 pm #73984
bobmaryann
ParticipantAfter selecting a cycle and then starting Prewash lights up then after a short while the cycle stops and fifth and sixth led’s flash. I cannot find this sequence on your error codes. Any ideas what this means?
Cheers, Bob
Sorry, got that wrong, I should have said fourth and sixth led’s are flashing.February 5, 2013 at 5:49 pm #389530iadom
ModeratorRe: Hotpoint Aquarius FDW60 Dishwasher
Could you double check which lights are flashing, 5 & 6 is not a recognised error code. 🙁
February 5, 2013 at 6:35 pm #389531washtronics
ParticipantRe: Hotpoint Aquarius FDW60 Dishwasher
heater circuit fault
February 5, 2013 at 7:01 pm #389532iadom
4 & 6 is a heater circuit fault. 🙂
However both the heater and the main pcb are known problem areas on these Indesit machines, the heater is always the best place to start.
It needs checking for insulation, continuity and resistance, with the machine isolated from the mains. If the heater is OK then it’s odds on the pcb is at fault. 😥
February 6, 2013 at 5:03 pm #389533bobmaryann
Thank you very much. I’ll check out the heater element.
February 12, 2013 at 4:22 pm #389534bobmaryann
I changed the heater and the error code disappeared. I started the machine and it ran through a cycle OK until ‘Rinse’ when part way through another error code appeared. Now the third LED is flashing and it sounds like the drain pump is running constantly. I cannot reset this condition and even after stopping and re-starting the condition remains.
Have I messed something up or is something else wrong?February 12, 2013 at 4:42 pm #389535iadom
You have a leak into the base. 🙁 You need to check the clips on the heater tube. Have some towels handy, you will get plenty of water on the floor when you tilt it.
Sent from my iPad using Tapatalk HDFebruary 13, 2013 at 7:22 pm #389536bobmaryann
Fixed it. Thank you all very much. Brilliant site. Very helpful.
