my dishwasher has stopped working, it trys to fill with water but then doesnt start any programs, we have taken the tray out of the bottom and there is not water in it, we have had the pump of and it is not jammed, we have emptied the salt container which was a little blocked, and we have tightened the bottom rotator arm, none of the above has fixed the problem, also the dishwasher filters have been cleaned and there is no blockage in the waste pipe. can anybody help please before i kick it to death lol
It’s code 5, which is down as the filter block error. Possible causes are choked filters (you’ve checked that), pressure switch not working, high-pressure switch not working (both could be blocked or switch failed) and the circulation pump not running. If none of these apply, the pcb has a fault and will need to be replaced.
