Hotpoint Aquarius FDW60 Fault Code
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Aquarius FDW60 Fault Code
  • #36606
    barf
    just received and fitted the new door catch for this machine. Ive now got a fault code indicated.
    Can anyone tell me the meaning – 3rd Green LED from Left (45 eco) lit only (4th LED from left including the red rinse aid LED)
    the only wiring i found it necessary to disconnect were the two contacts to the door microswitch, a black plug to the soap dispenser, a smaller white plug to the soap dispenser, and what im guessing is a sensor of some sort, also off the dispenser. Im sure i have the plugs in the right places (both dispenser onces being keyed anyway) but i could be wrong witht he sensor?
    any advice gratefully received
    Re: Hotpoint Aquarius FDW60 Fault Code
    Third light flashing indicates a flooded base.
    barf
    thats what i had gleaned from reading other posts, however, in this case the machine had been empty and dry for over a week, and this LED lit as soon as power was restored (it was steady as well, not flashing)
    as it happens, i used a bit of, ahem, experience (sparks being my trade, although im normally at a higher frequency than 50Hz 😀 ) and i tried holding a few of the buttons in for a while. Holding the start button until it stopped buzzing seems to have been some kind of reset. The LED went out, and ive run a ‘prewash’ as a test and all seems fine now 😀
    #251644
    Holding the start button in is the correct reset procedure. 🙂
    barf
    iadom wrote:Holding the start button in is the correct reset procedure. 🙂
    😀 Smashing! I had no idea, just assumed that there would be some form of reset, and its always good practice to do so after repairs. Not a bad guess then 😆
