Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Aquarius FDW70G Dishwasher Power/Resetting Issue
- This topic has 4 replies, 2 voices, and was last updated 14 years, 9 months ago by
Jules1974.
July 7, 2011 at 7:13 pm #63821
Jules1974
ParticipantHi All
I have a hotpoint aquarius FDW70G dishwasher and one day it just wouldnt turn on. Done the usual fuse checks etc so i thought id leave it for my brother to have a looksee. He said it turned on straight away for him but it wouldnt turn off and it was kind of going into this routine with the door closed ” beep, program 1 (you couldnt select any other) it would start a program and then it would reset itself” . I had a look and took out the control panel thinking it was that, when i put it back together it worked YAY!, for 10 mins and the whole routine started again.
It would either be locked in the off posistion where the buttons wouldnt help, or on doing some wierd power reset – beep . Like i said with the door closed it would start a cleaning routine, with the door open the panel would just beep – reset.
When the unit was off i went to move the washer out a little and then i thought i would try the unit and it started working great for about 5 mins this time. My best guess is i have a faulty logic board with the display on it, but id like the opinion of experts before spending £50 on a replacement!!.
If it would help i can post a vid upto youtube of what happens with it.
Cheers
JulesJuly 9, 2011 at 12:18 pm #355110iadom
ModeratorRe: Hotpoint Aquarius FDW70G Dishwasher Power/Resetting Issu
A bit of an unusual fault, it could be due to loose or poor wiring contacts but find which ones may be difficult.
You could tighten up all of the connectors to the PCB and visually inspect the wiring, pay particular attention near the bottom of the door where the looms passes into the base.
Failing that then the Indesit PCB may have failed, they are not known for their longevity. 😉
July 10, 2011 at 1:07 pm #355111Jules1974
ParticipantRe: Hotpoint Aquarius FDW70G Dishwasher Power/Resetting Issu
Hi thanks for the response,
By the PCB im assuming its the device with the LCD display and 5 bottons in the top of the door frame?.
Cheers
JulesJuly 10, 2011 at 3:54 pm #355112iadom
Correct.
July 18, 2011 at 6:33 pm #355113Jules1974
Hi, just to update i bought the logic board and it sorted my problem. 🙂
Cheers for your help.
