Hi, we had a short power cut while washing machine was on, when electric came back on, it started flashing H20. I cleaned hole at bottom of machine (2 coins and other small bits). Checked water hose wasn’t kinked, but still no water entering machine. Any advice.
The fill valves can fail without warning but it is a bit of a coincidence to have occurred after a power outage.
The H20 message can sometimes be a spurious error code generated by heating element down to earth amongst other things.
An electrical test of the fill valves would be the first step, could also be pressure switch but that should generate different error codes.
